The case temp is 25C, it has good cooling. The BIOS also reports 22C. My room temp is 20C.![]()
Results 31 to 34 of 34
I don't have a AMD 64 Sempron 3000 but I do have a AMD 64 Sempron 2800 CPU overclocked to 2.2 ghz with a ECS Nforce3 250 mobo. I was shocked to see how cool the CPU is with stock heatsink. The cpu temp is 32c when fully loaded. For video encoding the cpu temp never goes beyond 40c.
These AMD 64 Sempron processors are great for budget pc's. This pc runs faster and cooler than my P4 Northwood 2.26 pc.
@ lacywest
You know you could look up this information yourself. Most Socket 939 MB's will support AMD's X2 processors (dual core). As for the MSI K8N Neo2 - here's what I found at MSI's website, the following NEO2 boards support dual core processors:Can you show some links on this info .. for me ... Thank You
K8N Neo2 Platinum
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_cpu_support_detail.php?UI...MS-7025&kind=1
K8N Neo2-F
K8N Neo2-FX
Originally Posted by lacywest
check the MSI website .you may need to flash the BIOS on your MB to accept the dual core CPU
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
HVR-1800
By cathudog in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Jan 2008, 19:10 -
rjtech karaoke 1500/1800
By blackrain2008 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jan 2008, 10:12 -
AMD Sempron Vs Celeron-M?
By Super Warrior in forum ComputerReplies: 8Last Post: 14th Sep 2007, 23:08 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24
