  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    I've got Musicmatch 10 plus.
    There's an odd behavior that always happens. If I have a dvd or computer game in the dvd drive it will access while I'm playing songs. It's odd because it will switch from the library listing of all my songs to the view of whatever disc is in the drive. It's like its constantly looking for a media disc whether or not its an acutal audio cd. It's not that annoying but its weird.
    Anyone else have this pattern? Because its a little annoying if I'm loading a few songs at a time in my playlist instead of an album since I have to keep reclicking on "library" to get my whole collection. Just really bizzare.
  2. Member TaoTeWingChun's Avatar
    Jan 2005
    Mahopac, NY
    If you haven't, disable the "Auto Insert Notification" feature for your CD/DVD drive. That way, no matter what you put into it, your playlist will stay current even if you swap discs.
    Cheers!
    TTWC
    "I've got a present for ya!" - TTWC
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hey good idea. I'll check to make sure its off. Thanks.
