I want to upload my video to my pc from my dv-camcorder.
What kind of capture card do I need? I want to spend $50.00-$100.
So many different capture cards out-there to buy..
Can the same card have tv-tuner?
I have a dell dimension pentium 4 2.8ghz 1g-ram. (200g external hd)
I already have dvd-rw and will be using premiere pro and nero.
thanks for any replies.
Dv camcorder? Why not get a firewirecard? That way you just do a file dump without reencoding. Then you have the untouched files ready for conversion.
Or you might have a firewire port already if you have a pretty new computer with all the options.
Other than that an ati all in wonder card would work really well. Or a hauppage wintv pvr 250 (mpeg only).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yes, I need a firewirecard , what kind should I buy?
This would also work to transfer my old vhs movies to my pc?
I dont have a firewire port.
thanks for the reply... -
Like Yoda313 said; all you need is a firewire port on your PC. The video on your DV camcorder is already digital in the form of DV avi. Use the firewire to simply transfer (copy) to your PC hard drive.
Use winDV (freeware) set to type 2 DV to do the transfer to your HDD. Then use your software to edit, convert and author to DVD.
Look for firewire cards at Newegg.combits -
Only if your dv camcorder has a passthrough option. You'd have to check your manual to see if you can do that. Or you could record to your camcorder input than transfer that but it would double your transfer time and add wear and tear on your camcorder.Originally Posted by gomez1Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Whats a good analog to DV card with great quality?
By Onceler2 in forum Capturing and VCRReplies: 12Last Post: 2nd Dec 2009, 02:30 -
Once again - Good capture card for beginner
By MillowQc in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2009, 22:14 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51
