I'm sorry, if it is not the right forum, but i really need help.
i've been using Nero to burn videos to my cds for some time now and it always worked great, i have cds, that r 700MB and so far i always was able to burn up to 700MB to each disc, but now i've reinstalled windows and i had to reinstall all of my programms that i use, including Nero 6, and now for some reason, i am no able to burn 700MB to a disc anymore, only up to 650MB, if i put more it tells me that there is not enough space on the disc to burn my compilation, but that is not true, i have 50MB more avaliable on my disc, please tell me what is the problem, and what do i have to do to fix it.
Under File>Preferences>Expert Features make sure that the "Enable Overburn" isn't set to 74 min. If you're not using the overburn feature, just uncheck the "Enable" box. Pay attention to the warnings!
Other than that, you're using the wrong discs or have something wrong somewhere else.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 11:29 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
