Is there a program out there (free if possible, though I'd be happy to pay if its a goodie) that can join mpeg1 files without any loss of quality?
I'm looking for a programme that does a similar job to asfbin which I use to join WMV files (which I then edit, again without loss of quality, with Solveig video splitter, a great little application.
thanks
There is another method ... but it take's time and only freeware involved .
Though baldrick asked me why in another post .
It's the only way I found acceptable video quality retention , but dose involve re-encoding back to mpeg , though I prefer to encode as mpeg2 with the original resolution of the mpeg1 file .
I'll post this guide soon ... so everybody can see for themselve's just why I do it this way .
Then it'll be left up to user's if they find it acceptable for there own conversion's . -
If both fies have the same properties...jusr load them into dgindex and demux.... dgindex will do a demux joining the two files... just choose the option to demus audio and then the option "save project and demux video"... the the resulting files (video+audio) and mux them again (don't forget to check the audio delay - will be on the audio demux file names) using one of the tools posted on this site...
My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 08:54 -
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 13:01 -
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 3rd May 2011, 23:34 -
How do I joing 2 files
By wan2no in forum ComputerReplies: 4Last Post: 16th May 2008, 23:46 -
Joing two dvds?
By Castor troy in forum DVD RippingReplies: 1Last Post: 10th Feb 2008, 17:21
