hi, i was wondering if i buy a 42" lcd then isnt it going to have to be a widescreen, lets say aload of my fiolms are in full screen, will my tv/dvdplayer give me an option to change it and still look good, i know my 28" crt lets me choose between 4:4 and 16:9 but it looks a little weird
also if i bought a really big rear screen projector tv can i sort out my widescreen dvd's to play in fullscreen
last but not least, will g-spot tell me if a disk is full screen or widescreen by just showing the details,
i am dealing with dvd-r's
thanks
Pretty much all larger screen TVs (LCD, Plasma, rear-pro) are widescreen. Fullscreen programmes will be displayed with bars up the left and right sides, or in osme cases, you will have the option to cut the top and bottom off the screen (not a great idea). 16:9 enhanced material will fill the screen left to right, but mat still have bars top and bottom depending on aspect ratio. 4:3 letterboxed material will have borders all the way around unless zoomed in. Some TVs can do this automatically, some can't.
When using g-spot, look at the aspect ratio. For DVD, if it is encoded 4:3 it is fullscreen or letterboxed. If it is 16:9 then it is widescreen. For avi material, 1.78 or wider is widescreen, less if fullscreen or pillarboxed.Read my blog here.
thanks, nowadyas u can never win, hopefully one day ill have a 40ft homecinema in my house
i guess i can always make a nice stick on frame to minimiza my distraction
last question, home cinema's. are they widescreen or full screen, are they big tv's or is there something speciual -
They are what you make them. Pretty much all large screen TVs - of all formats - as well as projectors, are widescreen. It is the way of the future - TV broadcasts are mostly widescreen in many parts of the world, DVD and it's successors. I have a lot of 4:3 material - old movies etc - in my collection, which is one of the reasons why I haven't yet upgraded to a 16:9 screen. My TV has 16:9 switching, so I can get the most from anamorphic DVDs as well as my older stuff. That, and because I believe plasma is the worst display technology available at the moment, and LCD is only now becoming acceptable. Good projectors - true, full resolution, HD projectors - are still AUS$15,000 - AUS$40,000.
Home cinema isn't a standard. It's what you can afford to throw together with your budget. If it is a 76cm widescreen CRT, then that is what it is for you.Read my blog here.
dvd to vhs recorders and vice versa
By videohell in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Nov 2011, 07:02 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 20:30 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 17th Jul 2009, 00:01 -
Just kill the power vice using shut down.
By Xylob the Destroyer in forum ComputerReplies: 24Last Post: 16th Jun 2008, 20:50 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 08:11
