Hello guys.
I am capturing video from the tv using ProgDVB . This program make mpeg2 video files . But I have these 2 problems :
1) the mpeg2 files that I record and then play , they freeze time by time , like in slow motion .
I think it is a problem of the rendering mpeg2 codes , because they worked when I had other codecs installed , but I do not remember which one. Can u suggest me a mpeg2 video codec that does not freezes?
2)The recorded files are huge . 30 gb fo 25 sec of recording. Is there any way with ProgDVB to record in high resolution but with smoller file size ???
thank u
Originally Posted by marc21782000
Is that correct or a typo? and what is the file specs such as resolution and bitrate of your captures?
If you're creating enourmous files like that then they would require a huge amount of bandwidth to play... hence the reason it will slow down. Drive wouldn't be able to transfer the data fast enough.
Video Causing Computer to Freeze
By Ownaholic in forum Software PlayingReplies: 4Last Post: 26th Apr 2012, 13:10 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Video-TS files slow down and/or freeze
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 05:20 -
Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any video
By kary.sharma in forum AudioReplies: 1Last Post: 5th Dec 2008, 10:43 -
By kary.sharma in forum Video ConversionReplies: 1Last Post: 5th Dec 2008, 09:07
