I recently downloaded an XVID and realized that it is not recognized by my dvp 642 which has never happened before.
When trying to play it, the player starts reading then it automatically reverts back to the system menu. There is no disc error or anything.
resolution is 608*272
audio: MPEG Layer-3 at 120kbps
video: 23 frames/second, 99kbps, 12 bit,
any ideas why it doesn't play?
Because your 642 doesn't recognize that format. Whynot convert it to another format? Does it play on your computer?
Really, I thought this was a pretty standard format . . .It plays perfectly on my pc.
it doesn't support all xvid/divx features. try reconvert with avi recomp.
nice . . .looks like an easy to use program.
But do u know what are the correct settings to reconvert the files at, so that they can play on my dvd player? -
It's designed for highest divx dvd player compatibility so you should be able to use default settings. It doesn't add gmc and qpel which some divx dvd players doesn't support.
I tried using the program but It wouldn't convert properly, I believe the error was an audio error "mode . ." or somthing. I also tried divx converter which worked well but the audio was out of sync. Is there any other easy to use programs that can do both?
You can get more info here: http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
And there is a divx test cd at the top of the page here: https://www.videohelp.com/dvdplayersGoogle is your Friend
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
how to encode MPEG4 to play on a phillips DVP-642 player
By thejunkman12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2008, 08:32 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16
