    Mar 2006
    Ireland
    I need some help and not sure who to ask. Im new to this forum. I have a few movies on my laptop that i have on my desktop. they play on my desktop but not on my laptop. I have installed as many codecs as i can think of. Can anyone suggest a program or some codecs that play most files? I have vlc xvid divx bs player already. Apologies if it seems a stupid request
    Nov 2002
    Do NOT install codecs willy nilly. They are likely to conflict and mess up your system.
    Download and install GSpot, and check what codecs does the AVI use, THEN download specific codecs that will resolve your problem.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I thought VLC used its own codecs ?
    Media Player Classic might be a player to try as it is also highly regarded.
    But yeah .... what kschang said re: codecs and GSpot / AVICodec / VideoInspector.
    If in doubt, Google it.
    Dec 2004
    Australia
    VLC does. However it basically only uses OS libs for decoding so there are still various propritary formats that it doesn't support.
