Hi quick question, when i'm putting together the menu in Sony Architect, how do i set the default selected menu button, i can't seem to figure out where I change that.
You can use the Button Properties controls in the Properties window to edit the action and appearance of the selected menu button.
If the window isn't already visible, choose Properties from the View menu and click the button next to the Button Properties heading to expand the controls.
The color sets used to indicate selected, activated, or inactive, buttons are assigned in the Menu Page Properties controls. -
I did that, but it doesnt' say specifically where I can select the default selected button?
anybody know? i looked at everything -
I figured it out! It's not in the properties, but on the Left side where you see the menu layout, you can reorder the links there, and set the main link as #1 on the list
Menu 1 has always been the default unless there is an override.
Sony Vegas : How to restore LFE channel default setting?
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2011, 18:52 -
DVD Architect pro 5: problem with playlist, brancing and next (skip) button
By alfini in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2010, 06:28 -
Default Chapter title - DVD Architect 5.0
By KayAt in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 04:11 -
DVD Architect 3.0 - Next button does not work right
By the soundsmith in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2009, 12:44 -
Default highlighted menu button positions
By ToddS in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2007, 00:24
