Is there a way to convert VOB file AVI. I have a VOB and need to convert it to AVI for editing. I though VirtualDub does it, but apperantly it does not.
I can always burn the VOB to a DVD and then capture it, but the file is on 3MB and I do not want to waste a DVD.
Thanks.
virtualdubmod or virtualdub-MPEG2 should do it fine. With such a small file I'd recommend DV-AVI to retain sufficient quality.
If in doubt, Google it. -
I got the AVI file, but now I cannot load it into the After Effects. I get an error message "No such AVI compressor".
Maybe I am not saving it correctly.
what are the correct steps to save the file?
Converting .VOB to .AVI
By reysaj in forum Newbie / General discussionsReplies: 11Last Post: 1st Dec 2010, 09:24 -
By reysaj in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:56 -
Converting .AVI to .VOB
By agtjones in forum Video ConversionReplies: 3Last Post: 24th Nov 2008, 15:58 -
Converting VOB to AVI
By urb1972 in forum Video ConversionReplies: 8Last Post: 10th Sep 2008, 09:33 -
Converting .avi to .vob
By oldtrout in forum Authoring (DVD)Replies: 1Last Post: 10th Feb 2008, 09:11
