I have a Daytek DVD player(two actually) and they've played every movie fine for the past few years. This week I rented Water from Blockbuster and I after about 8 minutes in the film got choppy and unplayable. I returned it and got a different copy, keep in mind this film was just released on DVD last week so these copies are not scratched or anything. I put it in and I had the exact same problem! I took it upstairs to my other Daytek and it did the same error.
Has anyone else had a problem playing Water? Has anyone ever heard of a defective pressing being released to the public?
no one is reporting an issue with it -- but it may have a problem ... play it on another player somewhere else to check ..
maybe you got part of a bad batch ...
note - only released in canada so far i believe"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
nope -- i dont work in a video store , sorry
it won or was nominated for a few awards
http://imdb.com/title/tt0240200/awards"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i doubt they could afford to send out 100,000 copies for free - like some movies ..
Water damaged tapes
By NightFire in forum RestorationReplies: 2Last Post: 22nd Jan 2011, 23:58 -
Are water-shield discs necessary?
By SilverBlade in forum MediaReplies: 24Last Post: 24th Feb 2009, 21:40 -
Water for Gas?
By MeDiCo_BrUjO in forum Off topicReplies: 2Last Post: 17th Jul 2008, 16:10 -
water cooling systems
By romanstopme in forum ComputerReplies: 18Last Post: 29th May 2008, 10:12
