Ok i have been ripping dvds of my personal colleciton for a while now and i just tried 2 dvds and both have the same result, not sure if its cause i messed with a file splitting setting in dvd decrypter a while ago or what but when i throw the video_ts folder into vlc media player it doesn't play and i have 63 files in a folder, vob's, ifos, bups etc. I have stuff like VTS_05_MENU_1.VOB which i never had before.
My file splitting setting in dvd decrypter is set to auto.
Anyway if i try to load the dvd in dvd shrink i get an error and i also have no video_ts.vob and when i try to load it into vobblanker it says "referenced menu empty or does not excist in video_ts"
WTF did i do? This is driving me nuts cause i am losing my menus and i have to like reauthor my dvds now.
If you want the entire DVD copied to later open with DVDShrink then get DVDFabDecrypter.
DVDDecrypter's ripping capabilities are now outdated since it hasn't been updated for quite a while....and will not be any longer. -
Open DVDdecrypter, click on tools then settings, select any of the tabs (general will do) and click the defaults button at the bottom, then when prompted to reset defaults click yes .... dvddecrypter will now be as it was when you first installed it (note file splitting will be set to 'by file' and not auto ... 'by file is the correct setting)
Also check that you are ripping in the correct mode by clicking on the mode tab and selecting file mode and not ifo mode
Help Ripping DVD by Chapter with DVD Decrypter
By lukebrowning in forum DVD RippingReplies: 3Last Post: 11th Jan 2011, 00:04 -
Trouble ripping The Ugly Truth with DVD Fab HD Decrypter
By heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 14:29 -
Questions About DVDFab HD Decrypter; Ripping MPG
By neumannu47 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 18:55 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 00:41 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11
