There is a codec listed in the Tools Section called ASF Mpeg4". I followed the directions to download and install it. I got a warning just as I was about to install it that it doesn't match the Windows XP Logo Standard. So I decided to be safe and not finish installing it.
I am worried it might be something nasty. There was a warning from Microsof that this file could cause my computer system to be unstable.
Does anyone have any information on this topic? I just don't want to risk my computer system unnecessarily. Thanks in advance for any information you can give on this topic.
You're probably fine, but why not run an AdAware or Spybot scan if you're concerned ?
microsoft pops that msg up for any install that doesnt meet it logo program ...
99.9999999999% of the time nothing to worry about .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
Which audio codec I need to enable for playing "cook/ffcook" audi
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Sep 2009, 23:10 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 14:29 -
How to fix "twitchy' or "jerky" .asf files.
By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 17:48 -
Can't work with or find codec for "OpenDivx 4" files
By Lolipop Jones in forum Video ConversionReplies: 5Last Post: 14th Jun 2007, 15:43
