Results 1 to 12 of 12
check the first page in that topic...something is wrong and it seems to happens some times. probably your fault...
I found the bug! so it's probably not your fault...if you didn't code phpbb....
I came across a similar issue this morning when I came to reply to a PM I was sent a few days back. It has vanished from my Inbox - I definitely didn't delete it, because it was important.
Is it the same bug? -
Did you look at it before? I know if you send a PM then delete it from your outbox it gets deleted from the inbox of the recipient as well....
Essentially it's in no mans land until they open it. -
I did open it, so it would have moved from the "Outbox" to the "Sentbox" and even if it were deleted by the sender, it has been copied to my account so it shouldn't disappear.
if they deleted it on their end -- it will delete on yours (on some forums) , no mater where you have it ...
ive seen this before and though it is strange .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i installed this board about a year ago...stumbled back to see it had 7 updates and lots of security problems...it's one of those boards you have to baby-sit forever...always wondering of some kid has gotten in overnight...which totally blows
Thats the price of being the popular board system. In this case I'm pretty sure Baldrick does a good job of keeping upto date because we have not been hacked yet. *knocks on wood* Plus I imagine a whole lot of code is custom from Baldrick himself at this point. He seems to be quite good at PHP coding.Originally Posted by zoobie
It's simple to update and if you get on their update newsletter they'll send you a link for the update if and when one is avaialble. If it's a non-modified version you usually only need to upload the the changed files and run the database update script.. modified> install e-z mod and most updates will go over whithout to much trouble unelss the board is highly modified.Originally Posted by zoobie
Usually takes about 5 minutes at most.
Pinnacle 12: Project disappeared
By avz10 in forum Authoring (DVD)Replies: 1Last Post: 11th Apr 2011, 18:41 -
titles disappeared after conversion
By izzykatz in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 17:25 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 09:51 -
Lite-On 1673S disappeared...
By blasedeviant in forum DVD & Blu-ray WritersReplies: 11Last Post: 7th Feb 2008, 21:00
