I just installed a newer version of FFDShow and now .mkv files arent displaying the subtitles that they were with the older version. im not sure which version i had before.
Works fine here and I don't think the CVS has been updated since my build. Make sure that subs are enabled and accept embeded subtitles is also enabled.
Well VfW isn't used for playback and the only way to parse an mkv file via VfW would be VirtualDubMod and its mkv support is out of date. Plus it would need to parse the subtitles to ffdshow. The whole thing is just not going to work. So you are trying to re-encode, add hardsubs? You need to extract the subs first.
no, im not trying to reencode, im just trying to PLAY the file, its not playing the MKV with subs.
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
AVCHDCoder + FFDSHOW = Double subs problem
By kukkamies in forum SubtitleReplies: 4Last Post: 9th Feb 2011, 05:08 -
Windows 7 64bit + ffdshow x64 + TVersity 1.7.2.1 = no subs
By Igniss in forum Media Center PC / MediaCentersReplies: 0Last Post: 12th Dec 2009, 12:25 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 16:36
