Using vitual dub to save sound on a xvid to wav then besweet to re encode sound to PAL. Then setting the fps on the video to 25 in VD, even though the resulting video and sound are the same length when I join them back together in VD the sound is out of sync. Any ideas why, I have done this okay in the past.?
I have done this many times, exactly the way you say, and have had no problems, unless there was a resample 44.100 to 48.000 involved at the same time.
If so, I resample when extracting wav with VirtualDub, and if still happens, the I extract wav as it is, and resample with r8brain.
HTH -
I didn't touch the sampling freqs but I will have another go at it later and check that they match before and after.
If the sound is displaced by a fixed amount the original AVI file may have had an audio delay. By demultiplexing the audio and reencoding it you lost the audio delay. Examine the original source with YAAI to see if it had an audio delay. When you remux in VirtualDub use the same delay value (Audio -> Interleaving -> Audio Skew Value).
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
BD Authoring Problem: PAL to NTSC
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 23Last Post: 3rd Aug 2010, 17:00 -
PAL to NTSC Color Problem
By Drakul in forum Video ConversionReplies: 33Last Post: 29th Jul 2008, 01:58 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34 -
PAL to NTSC problem
By maca in forum Video ConversionReplies: 109Last Post: 1st Sep 2007, 21:30
