Ok, I've read most of FAQ's, but want to hear some opinions from people who tried differnt software.
I grabbed DVtype2 avi from my Canon mini-DV cam with KINO (i use linux for grabbing).
Then, I merged some avi's with mencoder. I got about 10 GB DV videos.
Now, I'm planning to use SONY DVD architector (winXP) to create 1-layer DVD(~4.5Gb) from these DV avi files. And add some menus, etc.
Is it right decision? May be there is some soft, that could deliver better quality. I saw PInnacle, Adobe , Ulead etc.. here. Which one to choose?
I guess, it depends on a codec they use to encode avi stream into MPEG-2.. Who is the best?
10GB is less than 1 hour. CBR at around 8500kbps + audio. Any decent mpeg encoder will do the job. DVD Architect has the Sony version of Mainconcept, and it does a very good job. CCE basic, Procoder Express or Tmpgenc will also do it easily. At that bitrate, HCEnc will give you good results and it costs nothing.
Read my blog here.
What is the difference between DV type1 and type2,
and how can I tell wich I have.
/BQIf everybody thought before they spoke, it would be very quiet. -
Originally Posted by bq
http://windowssdk.msdn.microsoft.com/library/default.asp?url=/library/en-us/directshow...deodevices.asp
DVDA wants Type2. Type2 carries audio as a separate stream. Type 1 has audio interleaved with video.
Canopus has a tool to convert.
https://www.videohelp.com/tools?tool=DV_Type_1_to_DV_Type_2_Converter
DVdate and others will tell you your type.
https://www.videohelp.com/tools?tool=DVdate
lossless (or minimum loss) flv video conversion
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2012, 06:59 -
Gameplay footage with minimum quality loss
By dBallaz in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2011, 07:02 -
How to Convert MKV Files into DVD Without No Loss Quality?
By devilcoelhodog in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2009, 17:55 -
Convert HD .MOV file to anything else with minimal quality loss
By Rapid99 in forum Video ConversionReplies: 3Last Post: 23rd Nov 2009, 23:45 -
Can I convert Xvid to WMV without any loss of quality?
By sofakng in forum Video ConversionReplies: 7Last Post: 19th Jul 2007, 10:49
