I recently made a completely standard NTSC DVD in TDA and after successfully burning I tried it in my Apex AD-1100W and it reads it and recognizes it as a DVD. Then, however, it won't play it it just opens the file explorer and has an error. I tried it later in my Polariod portable DVD player and it works fine. Any ideas on why this wouldn't work?
Results 1 to 18 of 18
What did you burn it with? Could be that your Apex doesn't like what it was burned with. I had an old APEX 3-disc player that would only read dvd's burned woth EZCD...
I burned a couple of the disks with the built-in DVD writing tool, the others just with a program I have for burning data dvds (drag the VIDEO_TS and AUDIO_TS folders on and burn) that I have used before and it works fine with the Apex. I now have found that my Toshiba SD-V290 will also not play some of these burned disks.
It also could be your Apex doesn't like the brand of dvd-r you used. I've run across this same problem with a Pioneer player.
TANSTAAFL -
Really, that could affect it? I just bought 100 DVD+R fujifilms
I'll burn a DVD+RW of this and try it -
I burned an identical copy of the dvd onto a DVD+RW of a different brand that I have and it works just fine on all players. I upgraded the firmware for the Apex, no change. Anyway is there something I can do to make these disks playable? What's wrong?
Are you using a Ricoh MP5240A with 1.19 firmware version? If not use this Flash utility to upgrade it.
Use the lastest version of TMPGEnc DVD author as its burning tool has been updated several times.
Also, make sure that you bit set your drive to DVD-ROM. I think you could use DVDINFOPro for this. -
I have the Ricoh MP5240A with firmware 1.11, I'm upgrading now Thanks!!
I think my TDA version is up-to-date, version 1.6.34.89
How can I check bit set in DVDINFOPro, I can't see the setting anywhere -
I did everything for the firmware update to the letter but it returns this error (before it starts I think):
I've tried several times and reextracted the ric file.Cannot update for different Type Code.
*** NG ** NG ** NG ***
Make sure Selected Source File. -
It s probably cheaper to sling the drive than get rid of the media ... get an NEC burns everytime no problem.. sell your old drive to somebody junior at work (unethical ?? ) or give it to charity
Well I'd rather stick with my drive if at all possible, I don't think that's necessarily the problem, its just not liking this media. What can I do to make the firmware update sucessful?
In DVDINFOPro there is in icon that looks like a CD and has +RW written in top of it.
Click on it. This should bring DVD+R/RW BookType BitSetting tool. With it set your DVD+R media to DVD-ROM.
It has been a while since I flashed a Ricoh burner. I do not recall the detailed steps. -
Ok well I went in there and it already says DVD-ROM:
I tried selecting DVD-ROM at the top but it didn't do anything, plus DVD+R is already set to DVD-ROMCurrent - ------
DVD+RW - DVD-ROM
DVD+R - DVD-ROM -
You look to have a single format burner. Burns + media only. It really is time to upgrade your burner, then. You can order an NEC burner from newegg.com. Total cost including shipping should put you at about $50US or less.
It could be your Apex player doesn't like + format. You make no mention of it playing disks you've burned in the past. To make sure, buy a 3 or 5 pack of +R disks, MIJ, if at all possible.TANSTAAFL -
I don't want to buy a new burner though, this one works fine with all other media I've tried and other disks (like memorex, sony, ect) all play fine in the apex. I'm just wondering what is different about the fujifilm that makes it not work and if I can correct the problemOriginally Posted by Prot
As said before, some players just do not like some brand of media. No explanation of why. It just doesn't. Something to do with the dye that is used, or maybe reflective surface.
Just chalk it up as a lesson learned. Your Apex doesn't like Fuji brand disks. In that case, a new drive probably would not correct the situation.TANSTAAFL -
Yep, that sounds like that's about the sum of it. Thanks for your help, I talked to best buy and I can return them so I'll do that and steer clear of fuji in the future
Well that was from a blank DVD+R that I had put into the drive. Talk about bizarre though, I tried one of the dvds once more in my apex and IT WORKS!! Ok, so I tried the others and sorted them out into categories and will give you info for each
1 DVD that works:
7 recognized as DVD but don't actually play:Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID RICOHJPN0R0
Media Product Revision Number 04h
UDF Format Type V1.02
UDF Volume Name
UDF Application id Prassi
UDF Implementation id Prassi
UDF Recording Date/Time (mm/dd/yyyy) 3/ 5/2006 19:14:03
Format Capacity 3.19GB(3.43GB)
Book Type DVD-ROM
Media Type DVD+R
Manufacturer Rated Speed Unknown
Data area starting sector 30000h
Data area end sector 198ABFh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Complete Media Code
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 1C 8A BF ................
00000010 00 00 00 00 00 00 07 52 49 43 4F 48 4A 50 4E 52 .......RICOHJPNR
00000020 30 33 04 38 23 54 37 13 00 44 73 00 84 6D 15 15 03.8#T7..Ds..m..
00000030 0B 0B 08 08 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................
Media Information
Media code/Manufacturer ID PRODISC R05
Media Product Revision Number 01h
UDF Volume Name DMBe
UDF Recording Date/Time (mm/dd/yyyy) 3/12/2006 13:29:01
Format Capacity 4.36GB(4.68GB)
Book Type DVD-ROM
Media Type DVD+R
Data area end sector 22E13Fh
Number of Layers 1
Complete Media Code
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 25 E1 3F .............%.?
00000010 00 00 00 00 00 00 07 50 52 4F 44 49 53 43 00 52 .......PRODISC.R
00000020 30 35 01 38 23 54 37 0F 02 56 6A 02 96 5D 16 16 05.8#T7..Vj..]..
00000030 0B 0B 0A 0A 01 1D 1E 0C 0C 12 12 01 00 00 00 00 ................
3 register as unknown:
Media Information
UDF Volume Name Musical
UDF Recording Date/Time (mm/dd/yyyy) 3/13/2006 17:18:33
Book Type DVD-ROM
Media Type DVD+R
Number of Layers 1
Complete Media Code
The only difference I could really see between them is that the one that plays has no name - and I remember the DVD burning utility I used asking me about using nonstandard characters in the title - I didn't think it was important but could this be me whole problem?
Edit - I burned another DVD with no title - just blank - and it won't play
Ok, after running these above tests I reset the laser inside by moving it all the way back. After that some of the dvds I have burned work, here is the info for one of them:
Some also do not work though, here is their info:Media Information
UDF Volume Name DS9_7-3
UDF Recording Date/Time (mm/dd/yyyy) 3/ 7/2006 19:54:26
Book Type DVD-ROM
Media Type DVD+R
Data area end sector 22E12Fh
Number of Layers 1
Complete Media Code
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 25 E1 2F .............%./
Any advice after all of this? It seems that maybe the media isn't bad but there is something else going on here.Media Information
UDF Volume Name Concerts
UDF Recording Date/Time (mm/dd/yyyy) 3/15/2006 15:54:11
Format Capacity 2.26GB(2.42GB)
Book Type DVD-ROM
Media Type DVD+R
Data area end sector 1210FFh
Number of Layers 1
Complete Media Code
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 15 10 FF ................
Uknown DVD - Is First play track the problem (TMPGEnc Author Works 4)
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2011, 07:26 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33
