I have successfully create a couple of VCDs with menus using VCDComposer along with VCDImager and CDRDAO. I understand how to create a menu flow using next, previous, timeout and numeric selections. I am confused about the return and default selection options. When I create them the VCD builds properly, but I can seem to trigger the selections from either my DVD player software or my DVD player. What do the return and default selections corrispond to?
What do the "next" and "prev" settings do?
All it means is that when you press the "next" button on your remote, it goes to what is defined in "next". When you press the "prev" button on your remote, it goes to what is defined in "prev".
The same is for "return" and "default".
If you hunt around your remote control, there will be a button called "return" and and button called "default". Often on DVD player remotes, these buttons are obscured. The "return" button may have its own button with a symbol of a crooked arrow pointing up.
The "default" button is often mapped as the "play" button on a DVD remote.
http://www.geocities.com/medinotes/vcd
Regards.
Michael Tam
w: Morsels of Evidence
Are There Synch Controls in WMP?
By Novice20 in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2012, 22:42 -
After Effects Camera controls help
By merciscool in forum EditingReplies: 2Last Post: 21st Dec 2011, 18:13 -
Winamp controls stuck
By solarblast in forum Software PlayingReplies: 0Last Post: 15th Jul 2011, 10:45 -
Volume Controls on a canopus ADVC300
By billycar in forum Capturing and VCRReplies: 8Last Post: 6th Apr 2010, 12:29 -
convertxtodvd-controls
By sumeshkri in forum Video ConversionReplies: 8Last Post: 1st Oct 2008, 23:11
