Hi,
i'm authoring a dvd with 10 music videos and i want that:
if you press skip back button (prev) on remote, you should go to start of the clip,
and f you press this button twice, you should go to previous clip.
How can that be done in DVD Maestro?
thats the default (but for most dvd players) .. though if you make each clip a separate title , it is for sure going to work this way ..
thanx,
i have separate titles, the project is done, with video, subtitles and two audio tracks in each title, so i cant go back and edit in one title with chapters.
i have a menu, where you can select each of the 10 titles and then if you press back you should go to the start, if you press forward you should go back to menu, there i dont need PREV twice.
in the menu there is also a button PLAY ALL and there i need this function.
It all works except if i press PREV twice in PLAY ALL mode, it gets always to start of the clip and not to previous clip. -
go into the list view and just set what the prev button does for each chapter or title .. its covered pretty well in the manual also , i just looked ...
i have set the prev button in the list view to the start od the track, i can't set it different because i have two modes - all and separate clips.
should i use command sequence - if i press PLAYall mode in menu, then the prev button sets to previous clip, and if menu in separate mode, to start of the clip?
but this is not what i want... to press twice to get back.
Remote control of computer?
By cwb in forum Media Center PC / MediaCentersReplies: 9Last Post: 29th May 2010, 18:29 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 15:54 -
Remote control for VBox?
By slytrans69 in forum Media Center PC / MediaCentersReplies: 0Last Post: 15th Aug 2008, 15:53 -
remote desktop control
By pcb in forum ComputerReplies: 11Last Post: 9th May 2008, 06:00 -
How to enable the program button on remote control using VIDEO_TS.IFO
By kraw in forum Authoring (DVD)Replies: 4Last Post: 26th Sep 2007, 21:59
