After a prety reliable year or so (and over 200 hours) of trouble free recording of both freeview and old VHS my machine just died!
No power whatsoever ! Did a static charge wipe out the proceser?
I admit that a week earlier I had hacked a region 1 code into ths region 2 R100A but the death came to light after I had preesd the" ON" switch after a few days left in the "OFF" position. The fuse was dead, but when replaced with a working one there was still no effect. Iwill add that I had attempted to install an update (downloaded from a link to MUSTEK on this site)via a CD-R. This appered to have no affect, but thats all I can add.![]()
Likely because there isn't much to be said. If a unit won't power on, there isn't anything that the average consomer can do themselves. It is time for a repair shop (if it is under warranty), otherwise, replacement is the cheapest option.
As to what caused the failure, there is no way for anyone to know aside from a certified technician after opening the unit and troubleshooting. All you and we can do is speculate and that won't fix anything.Google is your Friend
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 09:49 -
Digital-8 Camera Died - Help!
By douga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jul 2010, 13:52 -
FireWire port has died
By ZiGGY909 in forum Capturing and VCRReplies: 2Last Post: 1st Feb 2010, 07:33 -
Brittany Murphy Died
By Dv8ted2 in forum Off topicReplies: 4Last Post: 21st Dec 2009, 10:22 -
Version 2.1 died
By bfreas in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 18th Dec 2007, 02:42
