Has anyone tried this tool?--VH Screen Capture Driver. It's supposed to work from within other capture applications? Now that I think about it, isnt it redundant? I'm really baffled here.
I select it as capture device in ArcSofts Showbiz, and I get an infinite mirroring image , like looking in a mirror with another behind you.
(not sure if that describes it well)
Found in program folder the .exe called "VhSrnCapDlg.exe" , and opened that, getting a set of buttons etc. It allows you to select any portion of PC screen to capture, but not at this time. It's supposed to work from within another capture program ?? , but then I cant define what to capture?
You confused yet....?? I really just dont get what its for, or why I decided to install and try it.
Results 1 to 1 of 1
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
capture with twain driver
By zalves in forum Capturing and VCRReplies: 4Last Post: 27th Mar 2009, 14:46 -
Anyone has a clue how to capture voice chat from XBOX Live?
By jthompson99 in forum Capturing and VCRReplies: 2Last Post: 21st Aug 2008, 23:44 -
A tricky Driver for Capture Device Needed
By Digiliz in forum Capturing and VCRReplies: 9Last Post: 8th Jul 2008, 11:26 -
saving driver specific parameters for next capture
By hpishva in forum ProgrammingReplies: 0Last Post: 6th Nov 2007, 13:02
