Hi everyone:![]()
I think I have found the reason behind my strange result after I added a subtitle to my AVI file (read https://forum.videohelp.com/viewtopic.php?t=295607).
VirtualDubMod further compresses my already-compressed AVI file. For example, my AVI file has already been compressed from +1GB down to 700MB. After using VirtualDubMod to add a subtitle to my AVI file, I have a new AVI file that is now only +450MB. I believe this causes the inconsistency in quality of my new AVI file.
Is there any way I can add a subtitle to an AVI file, without further compressing the file?
Use the same bitrate as the 700MB source. 2-pass VBR is best. Actually, if you can, start with your original 1GB source. Each time you reencode you will lose a little quality. Or use soft subs which don't require any reencoding at all (but will require the right playback software).
Every time you change the video with VirtualDub it will decode the source, make the change(s), and encode the result.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Bluray/DVD Burned In Subtitles with no Video Compression?
By Tony Jenkins in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2011, 17:24 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
