I recently encountered a few movies (e.g., Magnolia and Titanic) which I can't process the .wav file extracted by DVD2AVI. I get the message "An error occured when audio is decoded." At first I thought I had accidently selected the DTS track but this seems not the case (judging by the bit 192kbps rate). I tried play the .wav file using Windows Media Player (even from another computer via a network connection) and got the message "The buffer is not big enough"
Anybody know what's going on?
you sure it's not a mpa file?
try to play it in WinAmp - it might have extracted it as mpeg audio -- you would then have to convert it to wav
give that a try -- if it does play in WinAmp double click on the info screen and it will tell you what type of file it is. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It won't play in WinAmp. File info box says its a PCM format, the same as it says for extracted .wav I can play. Humm. -
try extracting the .wav again w/ the following settings on dvd2avi->audio section
channel format->auto select
dolby digital->decode
MPEG audio->demux
if these r the settings u use...then try not down sampling or normalizing and see if you encounter the same problem...
also, try selecting another track to extract the .wav from...
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 02:54
