I don't know what's happening to me this week. I guess since I haven't really have computer problems in the past couple of years its all catching up.
I tried searching but I kept getting problems like the hard drive doesn't show up at all or not the whole drive shows up.
The problem is that sometimes the hard drive does not get recognized. So, the OS does not boot. I have to keep resetting the machine until the hard drive shows up in the bios. It eventually sees it but this is just frustrating. Anyone know how to fix this problem?
There is only one drive installed, BTW.
Results 1 to 16 of 16
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Sounds like the drive is about to die. These are exactly the same symptoms of a 200GB drive I had that died recently. It was about 4 years old and had been worked pretty hard so it wasn't too surprising. It was never a boot drive though but the rest of your symptoms sound just like the issues I was having with it.
Don't wait for it to die completely though. Take this opportunity to back up anything important off of it and get a new drive to replace it.FB-DIMM are the real cause of global warming -
Damn!! This is the drive I got last week.
was it a cheapo? the market's being flooded with cheapos now....$29 up...made in china i'm guessing
Maxtor 120gb drive at Staples. Made in Singapore.
try testing the maxtor drive with powermax which can be downloaded at the maxtor website. then you'll know for sure if the drive is dying a slow death.
Thanks budz, I will try that.
Bodyslide, I'm only using one cable. DVD drive seems fine.His name was MackemX
To concur with BodySlide , it doesnt work that way about the DVD drive working so its ok , as your problem is intermittent , it can still be the cable . And as RallyNavvie points out - back up ASAP .
Eliminate the second drive connected on the cable.
Get a different IDE cable.
Use a different power connector.
These things are all cheap and easy to do. They have also all solved such problems, on more than one occassion each, in the past.
Never trust software to tell you whether an intermittent problem exists or not. It can tell you whether the problem exists at the time the software is run, but not 5 minutes before or after. If the problem is constant, you don't need the software to tell you that.
Check your warranty. -
OK, I put in a new cable (right out of the bag) and it still did the same thing.
I unplugged the DVD drive and it booted up just fine. So it seems that the DVD drive is the cause of the problem somehow. Can somebody shed some light on the possible reasons?His name was MackemX
Same steps apply, check power and data cable, BIOS and jumper settings (misconfiguration?).
Thanks all. This is why I love this place.
I took out the DVD drive and set the jumper to slave. I plugged it in and all worked well.His name was MackemX
Originally Posted by Conquest10
You should do yourself a favor and set all your IDE devices to "cable select" so you never run into that issue anymore. Everything IDE device in my house is set to CS.FB-DIMM are the real cause of global warming -
In order to do that you must have Cable Select cables, and the positioning of the Master and Slave connectors Dictate to you the position of the drives.
How hard is it to set one Jumper to master, and the other to slave?
Some device combinations this must be reversed, sometimes both must be either master or slave. This only happens with an optical drive in the mix. -
CSEL is most convenient. Some drives (as pointed out mainly optical) are not happy with this setting, use master/slave. Don't mix CSEL with master/slave on the same IDE channel. Drives disappear when 2 are competing for the same spot, then usually 1 gets bumped.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Extra Hard drive not showing up in my computer?
By Ghtpua in forum ComputerReplies: 8Last Post: 27th Nov 2007, 22:19 -
Philips DVP5982 - USB hard drive folders not all showing
By PunkHippie in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Sep 2007, 12:58
