I am somehwhat new at this I've been making dvds for about 2 years now and been making vcds/svcds etc... for quite some time.. but I had a question concerning anime that I've downloaded with fansubs.. I wanted to know what is a good (don't know what to call it that 720x480 thingy??) At what number can I put it so I am able to see the movie clear enough and also see the complete subtitles that seem to get cut off all the time when I burn them onto DVD...
You may want to do a forum search on like "anime" and "subs". The topic has been covered before, but I don't recall the fix.
Google is your Friend -
install avisynth.
use fitcd to make a avisynth script that resizes and add black borders.
convert the avisynth script to dvd with for example convertxtodvd. -
Thanks for the info I'm gonna try that later on today.. Hopefully it'll work if not I'll ask for more help.. THanks!!
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 02:42 -
Converting Anime DVDs to AVI (AutoGK)
By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 04:25 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
Batch Convert AVI/OGM/MKV to DVD (anime)
By aktee in forum User guidesReplies: 480Last Post: 4th Nov 2007, 19:18 -
DVD to XVID - Anime
By psxiso in forum DVD RippingReplies: 7Last Post: 18th Jul 2007, 08:59
