I ran CrapCleaner for the first time a few days ago and it flagged all my '*.BAK' files (except Config.BAK) as junk, including System.BAK. I read on several web sites that you're not supposed to ever delete the Config.BAK or System.BAK files. So, what is the correct answer?
hi,Originally Posted by CSULB71
my opinion.....keep the config and system bak files...
*.bak files as a rule are just copies of files that were made when the orginal was changed for some reason..... generally you can delete all *.bak file and nothing will happen to your system!!!
HOWEVER.... you may want to keep certain bak files just in case the orginal goes bad or get delete for some strange reason....
myself i would keep the config and system bak files!!!!!!!! .....
more than once either my own system or when i was trouble shooting another.... that bak file came in handy to have... in order to replce the orginal corrupted bak file...... -
If you can re-create them by hand or have another copy, then delete them. If not, then don't.
How to delete/switch default language in a MKV file
By gquiring in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2015, 19:35 -
cannot delete vlc recorded file
By octeuron in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2010, 05:00 -
Delete Original file with MPEG4 Modifier Commandline?
By rvman in forum Video ConversionReplies: 6Last Post: 28th Jul 2009, 17:55 -
Batch file that can delete a specific file
By Dark_Raven in forum ProgrammingReplies: 1Last Post: 10th Jun 2008, 08:16 -
Can't delete AVI file
By Fbee in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 21:25
