Closed Thread
    Mar 2006
    I need some serious help and maybe you guys are the ones to do it. I’ve burned about 3 dozens DVD’s with little to no problems. All of a sudden I'm getting nothing but coasters. I’ve been using the same media and software. I changed nothing, but suddenly It’s doesn’t work. It starts the burn and get anywhere from halfway to 3 quarters of the way through. I tried changing From Nero 6 to Nero 7, nothing. I tried removing the DVD burner and reinstalling it. I tried burning an ISO file to the HD and using DVD decrypter to burn, again nothing but error’s. By the way I use DVD shrink to convert the files. I updated the latest firmware I could find for my burner but it doesn’t seem to matter. I looked over all the forums and I couldn’t find a solution to my problem. I’m at the end of my rope. Please help. Here’s my Nero error log. Thanks.
    P.S. I use two different types of DVD-R media, Verbatim and a cheaper brand. Neve had any problems with either until now. Thanks again.
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
    NT-SPTI used
    Nero Version: 7.0.0.0
    Recorder: <TSSTcorp CD/DVDW TS-H552B>Version: TS00 - HA 1 TA 0 - 7.0.0.0
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <TSSTcorp CD/DVDW TS-H552B>Version: TS00 - HA 1 TA 0 - 7.0.0.0
    === Scsi-Device-Map ===
    DiskPeripheral : WDC WD1600JB-75GVA0 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : TSSTcorp CD/DVDW TS-H552B atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : LG CD-RW CED-8083B atapi Port 1 ID 1 DMA: On
    === CDRom-Device-Map ===
    TSSTcorp CD/DVDW TS-H552B D: CDRom0
    LG CD-RW CED-8083B E: CDRom1
    AutoRun : 0
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 1023MB (1048048kB)
    Free physical memory: 552MB (565284kB)
    Memory in use : 46 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    16.3.2006
    UDF/ISO compilation
    7:24:56 AM #1 Phase 112 File dlgbrnst.cpp, Line 1724
    DVD-Video files reallocation started
    7:24:56 AM #2 Phase 114 File dlgbrnst.cpp, Line 1724
    DVD-Video files reallocation completed (no file modified)
    7:24:56 AM #3 Text 0 File Isodoc.cpp, Line 6410
    UDF document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    UDF Mode : UDF/ISO bridge
    UDF Revision : 1.02
    UDF Partition Type : physical
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    7:24:56 AM #4 Phase 111 File dlgbrnst.cpp, Line 1724
    DVD-Video files sorted
    7:24:56 AM #5 Text 0 File ThreadedTransfer.cpp, Line 525
    ReadBuffer-Pipe got 81920KB of Memory
    7:24:56 AM #6 Text 0 File Reader.cpp, Line 124
    Reader running
    7:24:56 AM #7 Text 0 File Writer.cpp, Line 113
    Writer D: TSSTcorp CD/DVDW TS-H552B running
    7:24:56 AM #8 ISO9660GEN -11 File Geniso.cpp, Line 3304
    First writeable address = 0 (0x00000000)
    7:24:56 AM #9 ISO9660GEN -11 File Geniso.cpp, Line 3304
    7:24:56 AM #10 Text 0 File Burncd.cpp, Line 3301
    Turn on Disc-At-Once, using DVD media
    7:24:56 AM #11 Text 0 File DlgWaitCD.cpp, Line 277
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2286127 (508:01.52, 4465MB)
    7:24:56 AM #12 Text 0 File DlgWaitCD.cpp, Line 289
    Write in overburning mode: NO (enabled: CD)
    7:24:56 AM #13 Text 0 File DlgWaitCD.cpp, Line 2568
    Recorder: TSSTcorp CD/DVDW TS-H552B, Media type: DVD-R
    Disc Manufacturer: PRINCO -
    Disc Application Code: 64, Disc Physical Code: 193
    7:24:56 AM #14 Text 0 File DlgWaitCD.cpp, Line 456
    >>> Protocol of DlgWaitCD activities: <<<
    7:24:56 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 846
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
    relocatable, disc pos for caching/writing not required/ required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [D: TSSTcorp CD/DVDW TS-H552B]
    7:24:57 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1058
    Prepare recorder [D: TSSTcorp CD/DVDW TS-H552B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
    0 | lead-in | 0 | 0x41 | 0x00
    0 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    2286128 | lead-out | 1 | 0x41 | 0x00
    7:24:57 AM #17 Text 0 File SCSIPassThrough.cpp, Line 34
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    7:24:57 AM #18 Phase 24 File dlgbrnst.cpp, Line 1724
    Caching of files started
    7:24:57 AM #19 Text 0 File Burncd.cpp, Line 4129
    Cache writing successful.
    7:24:57 AM #20 Phase 25 File dlgbrnst.cpp, Line 1724
    Caching of files completed
    7:24:57 AM #21 Phase 36 File dlgbrnst.cpp, Line 1724
    Burn process started at 2x (2,770 KB/s)
    7:24:57 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2669
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    7:24:57 AM #23 Text 0 File DVDR.cpp, Line 2469
    Recording mode: Sequential Recording Mode
    7:24:57 AM #24 Text 0 File MMC.cpp, Line 21541
    Set BUFE: Super Link -> ON
    7:24:57 AM #25 Text 0 File DVDR.cpp, Line 2624
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    7:24:57 AM #26 Text 0 File Cdrdrv.cpp, Line 8385
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 0 h
    Start sector number of the next Border-In: 0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    7:25:05 AM #27 Text 0 File Cdrdrv.cpp, Line 1195
    07:25:05.468 - D: TSSTcorp CD/DVDW TS-H552B : Queue again later
    7:45:26 AM #28 SPTI -1135 File SCSIPassThrough.cpp, Line 306
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 18 1B 40 00 00 20 00 00 00
    Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
    Buffer x04db0000: Len x10000
    0x00 00 01 BA 44 90 9F 0D 34 73 01 89 C3 F8 00 00
    0x01 E0 07 EC 81 00 00 F3 25 85 84 E6 33 1D 9E 75
    0x3F EE AE CC D4 BF D9 1B 2B B3 99 71 E2 65 14 58
    7:45:26 AM #29 CDR -1135 File Writer.cpp, Line 302
    Write error
    7:45:26 AM #30 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    7:45:26 AM #31 Text 0 File ThreadedTransfer.cpp, Line 222
    conversion idle, stopping reader
    7:45:26 AM #32 Text 0 File DVDR.cpp, Line 2866
    EndDAO: Last written address was 1579839
    7:45:26 AM #33 Phase 38 File dlgbrnst.cpp, Line 1724
    Burn process failed at 2x (2,770 KB/s)
    Existing drivers:
    File 'WNASPINT.DLL': Ver=V1.20, size=57344 bytes, created 2/4/2003 8:24:08 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 9/14/2005 2:17:44 PM (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    please don't cross post. ONE topic is enough.
    https://forum.videohelp.com/viewtopic.php?t=295909&highlight=
