I need some serious help and maybe you guys are the ones to do it. I’ve burned about 3 dozens DVD’s with little to no problems. All of a sudden I'm getting nothing but coasters. I’ve been using the same media and software. I changed nothing, but suddenly It’s doesn’t work. It starts the burn and get anywhere from halfway to 3 quarters of the way through. I tried changing From Nero 6 to Nero 7, nothing. I tried removing the DVD burner and reinstalling it. I tried burning an ISO file to the HD and using DVD decrypter to burn, again nothing but error’s. By the way I use DVD shrink to convert the files. I updated the latest firmware I could find for my burner but it doesn’t seem to matter. I looked over all the forums and I couldn’t find a solution to my problem. I’m at the end of my rope. Please help. Here’s my Nero error log. Thanks.
P.S. I use two different types of DVD-R media, Verbatim and a cheaper brand. Neve had any problems with either until now. Thanks again.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <TSSTcorp CD/DVDW TS-H552B>Version: TS00 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TSSTcorp CD/DVDW TS-H552B>Version: TS00 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1600JB-75GVA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-H552B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LG CD-RW CED-8083B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW TS-H552B D: CDRom0
LG CD-RW CED-8083B E: CDRom1
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 552MB (565284kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.3.2006
UDF/ISO compilation
7:24:56 AM #1 Phase 112 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation started
7:24:56 AM #2 Phase 114 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation completed (no file modified)
7:24:56 AM #3 Text 0 File Isodoc.cpp, Line 6410
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
7:24:56 AM #4 Phase 111 File dlgbrnst.cpp, Line 1724
DVD-Video files sorted
7:24:56 AM #5 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
7:24:56 AM #6 Text 0 File Reader.cpp, Line 124
Reader running
7:24:56 AM #7 Text 0 File Writer.cpp, Line 113
Writer D: TSSTcorp CD/DVDW TS-H552B running
7:24:56 AM #8 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
7:24:56 AM #9 ISO9660GEN -11 File Geniso.cpp, Line 3304
7:24:56 AM #10 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
7:24:56 AM #11 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
7:24:56 AM #12 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
7:24:56 AM #13 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: TSSTcorp CD/DVDW TS-H552B, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
7:24:56 AM #14 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
7:24:56 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [D: TSSTcorp CD/DVDW TS-H552B]
7:24:57 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [D: TSSTcorp CD/DVDW TS-H552B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286128 | lead-out | 1 | 0x41 | 0x00
7:24:57 AM #17 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
7:24:57 AM #18 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
7:24:57 AM #19 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
7:24:57 AM #20 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
7:24:57 AM #21 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 2x (2,770 KB/s)
7:24:57 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:24:57 AM #23 Text 0 File DVDR.cpp, Line 2469
Recording mode: Sequential Recording Mode
7:24:57 AM #24 Text 0 File MMC.cpp, Line 21541
Set BUFE: Super Link -> ON
7:24:57 AM #25 Text 0 File DVDR.cpp, Line 2624
Start write address at LBA 0
DVD high compatibility mode: Yes
7:24:57 AM #26 Text 0 File Cdrdrv.cpp, Line 8385
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:25:05 AM #27 Text 0 File Cdrdrv.cpp, Line 1195
07:25:05.468 - D: TSSTcorp CD/DVDW TS-H552B : Queue again later
7:45:26 AM #28 SPTI -1135 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 18 1B 40 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x04db0000: Len x10000
0x00 00 01 BA 44 90 9F 0D 34 73 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 F3 25 85 84 E6 33 1D 9E 75
0x3F EE AE CC D4 BF D9 1B 2B B3 99 71 E2 65 14 58
7:45:26 AM #29 CDR -1135 File Writer.cpp, Line 302
Write error
7:45:26 AM #30 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:45:26 AM #31 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:45:26 AM #32 Text 0 File DVDR.cpp, Line 2866
EndDAO: Last written address was 1579839
7:45:26 AM #33 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 2x (2,770 KB/s)
Existing drivers:
File 'WNASPINT.DLL': Ver=V1.20, size=57344 bytes, created 2/4/2003 8:24:08 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 9/14/2005 2:17:44 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 18 of 18
Have you installed any new software recently?
I was getting burn errors after installing Skype. I removed Skype from my start-up programs and everything went back to normal....just an example mind you....other software my cause the same problems.
Also a problem with your log:
I know you've tried several brands...but these are generally viewed as the bottom of the barrel DVD's. -
This happened to me a couple years ago. If it's not the software or the quality of the disks then most likely it's a problem with the burner- they do go bad eventually.
The last two DVD burners that I've had die on me, did almost without any warning. The DVD laser can and does burn out even after just having burned a perfect disk. The next time you try it it won't even recognize that you have any media in the drive. There are apparently two lasers one for DVD and one for CD. Different diameters and or color beams maybe?? I am not sure. In those two mentioned cases, I did not experience a trouble period of time where burns where begining to fail, they both simply stopped burning.
Have you tried to successfully burn a CD? That will tell you if it is a software or PC problem or the DVD Burner itself. You might find out that you can indeed burn a good CD and not a DVD. You could always try a differnet drive from another machine or just get a new one. Excellent ones can be had for ridiculous low prices this day.
By the way, if I only had a dollar for every time someone tells me that nothing has changed in or on their computers,,,,No DVD can withstand the power of DVDShrink along with AnyDVD! -
Thanks for the feedback guys. As for the disc's, i know there not the best (x-mas gift) but they have been succesfull unitl now.
When I say I didnt change anything on the computer, I mean i did'nt "0ntentionally" change anything. Dont think i installed anything different. Cant find anything different. i was looking for that sony root kit on my computer but the few scans i ran cant find it. Dont know if that would stop the burn or not.
And the burns start, they just dont finish. Do you think the laser would give out during the burn? Sounds kinda odd. Hope that's not the case.
Again, i appreciate the feedback. -
Is there a reason you're looking for the Sony rootkit? I performed several tests a few months ago and was able to determine that even using proper removal procedures in, at best, erratic computer operations. I knowingly installed it and the only way I was able to get rid of that infection was to format. The DRM company paid me for my losses and Sony re-issued my CDs sans the rootkit and gave me 3 Album downloads.
When I say I didnt change anything on the computer, I mean i did'nt "intentionally" change anything. Dont think i installed anything different. Cant find anything different. i was looking for that sony root kit on my computer but the few scans i ran cant find it. Dont know if that would stop the burn or not.
Originally Posted by Stumpy
If you try different media and different software and still have the same problem, you could try to move the drive to a different computer and see if it works there. If none of that solves the problem then it's a pretty sure bet that there's a problem with the drive. If one of those things stops the problem then it's probably not the drive. -
I was looking for a sony rootkit because I think i might have backed up a sony dvd. I put in a dvd and the whole computer slowed down after that. BUT.... it was still burning dvd's with no problem. Thats why i thought maybe a root kit might be taking it's toll on my system
Let's go back to basics here.
Change the cable that connects your DVD drive(s) to your motherboard. I had a similar issue - burns would complete but be full of errors. It was the cable. -
new cables didnt do the trick, I think it must be a software problem but I cant figure out what.
Stumpy,
You have explained (above) my problem EXACTLY, right down to the error #1135. It happened all of the sudden, after no software or hardware changes to my system. It was late February to early March when my burning turned into a coaster maker. I tried downgrading my Nero version to the oldest i could find trying all different ways to rip & burn with the exact same result - after 8% burn complete - write error #1135 and a new coaster.
This weekend i finally had the time to sit down and get it fixed. I did 2 things only so not sure which 1 fixed it but am back to getting good burns now. I made no other changes to my software or hardware setup. 1st I upgraded to the latest burner drive firmware (Sony DRU-700A). Then I downloaded the latest ASPI driver from Nero (http://ww2.nero.com/nero6/enu/ASPI_Driver.html) and copied it into my Nero dir, rebooted and whalla, proble solved. back to perfect burns again.
I think something from the internet took me out. There were a few windows security updates in the last few weeks which I let install, not sure - just a thought. Am suspecting something like this becuase my problems started when I wasnt making any software or hardware changes to my system. -
mhub1,
thanks for the reply. it seems that everyone gave up on my problem. I'll give it a shot. My DVD-burner is pretty old so i dont think I can find a newer update thatn I have. I've been looking. But I'll try looking for a Nero patch to help.
I'm not sure what took my system down because i cant find any unusual adware or virus's on my system. i actually think that is was a DVD that i backed up. Things seemed to slow down during certain DVD's. cant figure out why. Hopefully your suggestion would help. thanks again -
I once had the very same problem .... i tried everything from reinstalling software to completely reformatting the hdd ... no joy ... then i thought ... i haven't tried the obvious .... cleaning the lasers lens, so i purchased a lens cleaner disk and after running it in the drive several times things began to improve slightly as some disks would burn completely but others would fail, i decided to remove the drive from the pc and remove the cover from the drive and clean the lens manually with a cotton bud (i believe they're called q-tips in the U.S.) and the solution that came with the cleaning disk .... after reassembling, the drive worked great and continued to do so for more than a year until it was replaced by a faster drive (it was only a 4x dvd-r/w drive) never had another coaster
Hey Stump,
the more i think about it, it seems like my ASPI driver got stompped. I use Nero to burn with so that is where i went for a new aspi driver. all i know is it works perfect now, and the only other thing i changed was the burner firmware. wish i would have done the 2 things seperately so i would have known. didnt want any more coasters (my recent supply is huge).
if you use Nero to burn, go there for a new aspi driver with the link i mentioned.
i'm glad you mentioned you were experiencing the same problem i was seeing (exactly) as it helped me track it down faster - i was considering a reformat c: . it wouldnt suprise me if 1 of the movie studios are putting out little software tweeks to keep us on our toes.
Hope you get going again. Good luck. -
I havent had a chance to update Nero yet, but now that I'm thinking about it, I had the same problem trying to burn the disc with DVD decrypter as well. So i'm not sure that would be the problem but I will give it a shot anyway. And I'll definatly try and clean the lens. It wont hurt I guess.
hey stumpy don't change your burnet these error can occur if the files that you are burning or if they are video files conatin charachters like these ][ it hapened to me before try to rename the file and remove [] or ~é charachters especially if they in the end of the files some movie files are like this [5353873] at the end remove all these charachters basichly remove all the charachetrs other than letters and numbers if you wanna seperate the letters or words with something use underscore _ but first try jsut letters and numbers and tell me how it worked
also if you have some japanese charachters or chinese or korean or something in the folder where the image you wanna burn is rename the folder or also the file that contain the charachters
use cheetah dvd burner if you wanna burn dvd data it's a good software tell me how everything worked
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 11:29 -
Burn Errors due to MPGV ?
By mrlewp in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2010, 19:54 -
New here- trying to convert files to burn to DVD using AVStoDVD... errors..
By tressls in forum Authoring (DVD)Replies: 6Last Post: 7th May 2010, 16:25 -
Encoding errors, cannot burn DVD
By Surber in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2010, 11:55 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
