    Dec 2001
    Arizona, USA
    I read your tute on putting VCD to DVD, but it looks as though this is for converting DVD to VCD then putting back on DVD. Will a standard VCD encoding work without the multiplexing?? In other words can I take my home movies and cap at VCD standard(MPEG) and just burn with Nero/VCDEasy/TSCV...? This would pretty much cover all my home vids And since quality is poor in, quality is poor out!!
  2. I may get some of the nuances wrong, and I am sure the semantics will be wrong, but I think I know what you want to do, and if I am right, yes it can be done.
    If you want to burn VCD quality mpgs to a DVD (which is what I think you want to do), the answer is yes you can. Just make sure that your audio is encoded at 48 KHz, and you will be fine to burn mpg 1 video onto a DVD and play it in a DVD player.
    It really is a great way to go, since the quality was questionable to begin with. I did this with the Band of Brothers series from HBO, since I recorded them on VHS, I knew I wasn't going to gain any quality by encoding them as MPEG 2's, so I encoded them as MPEG 1's with a 48 KHz audio stream and then was able to burn all of the episodes (totaling 6 gigs) on two DVDs. Again, I can't say enough about how great it is to be able to burn VCD quality stuff to a DVDR!
    One final note, if you are burning to a DVD you will need to use some sort of authoring prorgam, in other words, you can't burn the VCD file structure to a DVD and have it work, unfortunately things don't work that way. Spruceup is a pretty easy/good program, as is Ulead's DVD program although ulead's program doesn't give you a whole lot of flexibility on the look and feel of menu's.
    Hopefully this helps you, if not, just be like my wife and ignore me
    Dec 2001
    Arizona, USA
    Thanks for the input I'll give it a try.
