alright i followed all the instructions and cut the movie into two halfs like it says, the first half goes fine i burn it wit nero and it plays fine, so then i start onto the second half of the movie and it gets about to 40 somethin % and a illegal floating decimal error pops up how can i fix this? or what am i doin wrong? so far this has happended to 2 movies i tried burning and i figured it was just the other disk so i tried this movie and the same problem. im using the tmpgenc encoder like it said.
<font size=-1>[ This Message was edited by: n|ghtmare on 2001-12-31 10:33:01 ]</font>
Results 1 to 1 of 1
Any current ffmpeg builds floating to the top?
By Calidore in forum Video ConversionReplies: 0Last Post: 11th Jun 2011, 14:22 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 18:41 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22
