I have searched all thru this forum and it seems to me thatthe "pc" people won't give you the time of day "it cannot be done on a mac (compleatly ignoring in the tutorials) even if you do a wide search, Those other pc people act like Mac's don't even exist.
It' got me so ticked off wasting over an hour and i get nothing and i m going to recieve on Friday 350 Taiyo Yuden DVD-R 4.7GB, 8X, 100-Packs for a lagre project that going to take about 3 months to compleat.
I wont go into details over the past 4 months learning, searching, and posting
I use MTR from the DVD to the HD if original i dual layer or anything thats over 4.36gigs i simply use DVD2onex, i can do it in my sleep.
i don't want to change the end result to be any different
"full disk extraction" 3 steps ripp it, shrink it, burn it.
Now i see more disks with deliberat dummy VOB's.
The first step is to ripp it to the HD , it seems obvious that this can 't be done deleating or padding the ofending VOB's whick of course can't be done.That i know of I have not been able to ripp the whole DVD, i've tryied both options pad it and it my make it all the way but takes at least twice the time to x-fer the disk but the copy comes up with a smaller disk the the source DVD.
i use this forum quite a lot latley and have have gottin out of a lot of sicky situations.
The people are very helpfull, without it im sure that i'd have no hair by now.
Lot of great people and because of everybodys help i would not have gained as much info, the info cn be quite overwhelming as there is so much info here, i could not have gained the knowlage without the input i recieve from all the great people here.
So here i am again pleading foranswers with a dead line 2 feet behind me.
One more thim HELP please.
sknoxx
Results 1 to 12 of 12
You don't mention what version of MTR you're using. I bet you could use a newer version.
Originally Posted by Case
MTR 2.6.6
It's only happened on 3 DVD's , i can deal with one or two, i just go and buy them again.
Now it's happened on 2 disks from Star trek tng. from 2 diferent seasons you can't buy one disk you have to buy the entire boxed set i came across one of them from the first season.
You can't even do straight disk to hard drive, draging the files off the DVD, onto your hard drive, i take this as a new copy protection sceam
Is anybody looking into this for a work around? , it seems to have started within the last 2 months
sknoxx -
It is a new copy protection scheme, and even the latest "donation" version of MacTheRipper doesn't deal with all titles successfully. At least not for full disk extraction. Movie Only seems to work, but in a compilation like the Star Trecks you have, I'm not sure if that will work.
Check the ripdifferent.com site (MacTheRipper forum) for more details. -
Yes (Nods to case and Willrob) MTR 3.0r12 is the first
piece of the puzzle you need. The second is Toast 7.
The copy scheme is RipGuard, and the only (shrink)
app that handles it is Toast 7.
step 1. use MTR 3.or12 to rip ( it will tell you Deliberate Bad sectors)
step 2. Process the outputted folder with Toast 7 to disc.
DVD2ONEX has dropped the ball on this issue
as I reported several weeks back.
The only issue solution for Full Disc Ripguard is to
switch DVD2ONEX out with Toast 7.
Oh, and of course make sure you run OSX Tiger and QT 7
(nod to Frobozz)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
MTR r13 will be released soon. It has been tested and works on ALL the latest copy protection. Be sure to donate and get a copy. Its well worth it! For more information, visit ripdifferent.com
"May the Force be with you!" -
Originally Posted by terryj
I don't follow you
I cannot find any vers. of MTR higher than 2.6.6.
switch DVD2ONEX out with Toast 7.Im running Panther, last vers.and Toast 7 and QT 7.4Oh, and of course make sure you run OSX Tiger and QT 7
(nod to Frobozz)
Please give me a more step at a time.
For the most part i don't understand
And will the end result in a full disk extraction?
I don't understand how to extract the files to disk i have
been unsucssesful no matter what i do
Thank you with your help
sknoxx -
You have to go to www.ripdifferent.com, go to the MacTheRipper forum and get the info on donating. They send you a link to download the latest version (currently MTR3 r12).Originally Posted by sknox"May the Force be with you!"
[quote="sknox"]
Follow G4jedi's advice/steps to get new MTR.Originally Posted by terryj
Then Using new MTR, rip the disc using the Full DISC ArrCCos method.
Then, once it is complete, it will give you an outputted Video_TS folder.
Open Toast 7, select the Video tab,Seelct DVd from Video TS folder, drag and drop the output onto the open tab in Toast, insert a blank, and burn the disc. This will get you what you need."Everyone has to learn, so that they can one day teach."
Urban Mac User -
OK I'm having problems as well...
I used to use MTR 2.6.6 just fine, and then all of a sudden it just stopped working for me. I get the following errors:
"failed opening IFO for title set 0
mirror of VMG failed
mirror of dvd failed"
It does this even with dvds i have ripped previously, so i know its not just copy protected jazz.
I tried uninstalling it and reinstalling it, and i even got the newest version but it does the same thing.
Can anyone help? -
spunkyc, Why are you Hijacking this thread when you have one started already?
spunkyc, please do not hijack others threads. Continue in your own: https://forum.videohelp.com/topic338190.html#1760459
And please read our rules before posting.
Moderator redwudz
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 04:23 -
Batch extraction of audio streams from mpg/vob?
By gaikokujinkyofusho in forum AudioReplies: 1Last Post: 4th Dec 2010, 04:15 -
Vista 32 bit ... Disk full? but only 35GB files on a 108 GB c:\ partition.
By edDV in forum ComputerReplies: 6Last Post: 6th Jul 2010, 02:55 -
combining .VOB files for DVD player disk
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 12th Apr 2008, 06:39 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 20:13
