I have several .mp4 video files that I want to make VCDs out of. They play great in Quicktime so I know they work, but what program can I use that will convert & burn them as a VCD? Or what other method should I go about to convert these .MP4s to VCD?
You might try TMPGEnc encoder and the TMPGEnc Mov plugin. Or SUPER and VCDEasy.
If they are QT style MP4's, the easiest way would be using QT Pro to convert them to AVI, then from AVI to MPG, then author the MPG into VCD. (Or can you go from MP4 to MPG in one step? Haven't used QT Pro in a LONG time)
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 19:35 -
Can someone make me a ffmpeg file for normalizing mp4 files? I am Clueless.
By xrayengineer in forum DVD RippingReplies: 2Last Post: 3rd Feb 2011, 19:46 -
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 04:26 -
How do you make subtitles for .mp4?
By showmi in forum SubtitleReplies: 0Last Post: 7th Jul 2008, 11:55 -
Trying to get Yamb to work with a AC3 file to make a mp4...
By AndyD in forum AudioReplies: 2Last Post: 12th Jan 2008, 23:07
