I need to convert some music mp3 > wave file>ac3. What do you suggest to use please. This is to use in my video's.
Results 1 to 9 of 9
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
It does support mp3. libavcodec/format can handle most commonly used stuff.
mind you, doing this will deteriorate the audio quality some, depending on what your doing, you may be better just leaving it in mp3...if you need it in ac3, though, you would be best to resource it directly from the disc it came from (if we are speaking audio cd sources, of course, not like recordings done other ways)
Whatever AC-3 encoder you use I would make sure that you first get your source file into a WAV file fisrt ... then convert to AC-3.
Alot of people try to go straight from say MP3 to AC-3 without first converting the MP3 to a WAV.
So at least you got that part correct
Most AC-3 encoding solutions are expensive. ffmpeggui is really the only freeware solution that I am aware of.
However the company that makes TMPGEnc DVD Author has an AC-3 encoder you can buy that is meant to be a plug-in for TMPGEnc DVD Author but can also work as a stand alone AC-3 converter. I costs $29 but is considered to make better and more compliant AC-3 audio files than ffmpeggui.
Here is a direct link ---> CLICK HERE
Fail to see any real difference between decoding to wav and encoding and encoding direct from mp3 other than the fact that one takes longer and requires more HDD space.
I base my comments on the fact that in the past I've had trouble with BeSweet when I didn't start out with a 16-bit 48k 2 channel PCM WAV file. Maybe it was just a BeSweet "quirk" but other than the slight extra time and HDD space (both of which are minor) I think it pays to play it safe.Originally Posted by celtic_druid
Yes, mp3 to wave first then wave to ac3. I do have tmpgenc dvd author but my editing system is not connected to internet, and will never be. So I heard Tmpgenc dvd needs internet to keep ac3 up to date or something to the effect it needs the internet. I don't know, I believe I read something before about that.
cdex maybe my answer. Thanks
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
Weird wave/MP3 file
By AlanHK in forum AudioReplies: 2Last Post: 20th Nov 2008, 01:33 -
command line MP3 to WAVE?
By AlanHK in forum AudioReplies: 5Last Post: 1st May 2008, 07:10
