    Mar 2006
    Canada
    Hi, I got a Citizen JDVD 3830 used, the Norcent Clone, and when setting it up I did somthing STUPID, I switched the video to CBY (or whatever the hell its called) and now I can't get it back! Could some kind person tell me how I can get the video back so I can see it, thanks!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The only way that I am aware of is to connect it to a TV using that connection, then change it.
    Most units have a timer(failsafe) on the video setting so that if you change, there is a message that appears on the screen asking if you can read it, if you don't press ok during the message , it reverts back.
    Google is your Friend
    Mar 2006
    Canada
    Thanks KK, if thats the only way I'm skruud. If anyone else knows another way OR has copy of the Manual, please tell me.
    The stupidest person is the one who won't ask a question.
