I never used a Dual Layer Disc, but how does it work?
That means i can put 9 GB of Data? Do i need to do anything differently when authoring the dvd?
Results 1 to 13 of 13
dual layer or DVD+R DL or DVD-R DL are 8.5GB, but holds something like 7.95GB. Dont need to do anything different when authoring, besides making sure that 9GB setting is used. Recommend using CopyToDVD to burn. Nero 6 is known to have issues when burning at the layer break. People have experienced pauses, shudders, skips and choppy player at the layer break. Nero 6 was hit or miss. At $2 a pop, you cant afford to have even one miss. Go with Verbatim DL discs.
I'm going to use Sony Architect to burn a dual layer DVD
Is there anything I should know before doing so, is there any disadvantage to using a Dual Layer disc these days? -
The disadvantage IMO is cost for one and not as widely compatible as single layers. some players, dvd drives will have problems reading them.
Is this true, i never heard of a person having trouble reading a dual layer dvdOriginally Posted by Treebeard
aren't 99% of the dvds that are sold dual layer -
trouble reading a 'burned' dual layer. pressed dual layer is different.
My dvd drive doesnt like to read burned dual layers. -
My XBox and my Toshiba will both play +R DL media with no problems. My PS2 and my Pioneer DVD Recorder won't recognize the disc.Originally Posted by snapware
Memorex DVD+R DL
anybody have any experience with those?
LloydAZ: Does ur PS2 and Pioneer play professionally pressed Dual Layer disc -
Well,,,,, if you are truly serious about his, you need to out put to DLT and give that to the production house to produce your pressed disks. You just don't "Burn" a DL "Master" and hope that it is good enough. It may be and then again it may not. DLT ( Digital Linear Tape) is the industry standard for producing pressed disks I believe.well I'm gonna burn 1 master copy and then have it pressed =)
If the above quote was not your intention than I hope this was of some help anyway.No DVD can withstand the power of DVDShrink along with AnyDVD! -
What is DLT?
What if it's not Dual Layer, can a single sided burn dvd be sent to replication house with no problems? -
It may be and then again it may not. DLT ( Digital Linear Tape)No DVD can withstand the power of DVDShrink along with AnyDVD!
Yes, Professionally pressed dual-layer media plays fine in both, just not the +R DL. It could be the book type setting which I am not sure if I can do with my burner or not. I haven't wanted to mess with upgrading the firmware as it works fine with everything else. And DL media is still a bit pricey for me to mess around with too much.Originally Posted by snapware
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 10:36
