I'm trying ConvertXtoDVd out and it looks really good.
But i added 2 avi's (to make one movie) and it made chapters for the first avi then the second. eg 5 then 5
how do i make it add chapters from start to finish eg 1 to 10
do i have to join avi's before i put them in ConvertXtoDVD? would this cause sync issues?
I joined the AVI's with virtual dub and got sync issues on the second half of movie.
So i think best option is to just add the 2 avis straight to ConvertXtoDVD but dunno if i can get chapters in sequence from start to finish.
Does anyone know? -
Each file will be a seperate title, but you can always just import the two titles into authoring software that supports authored DVD material (TMPGEnc DVD Author does, and I'm sure a few others would too), add both titles to the one track and your chapters should "merge" so to speak.
If in doubt, Google it. -
that worked a treat the first time (which was about 5 weeks ago)
now when i try to open the folder with tmpgenc author to join titles i get an error in chinese. -
(forum searched for "tmpgenc dvd author divxtodvd error")
I have received this error message from time to time. I don't know what causes it, but the fix I've always used has been to get rid of all the IFOs and BUPs that DivxToDVD / convertxtodvd creates (just leaving the VOBs), then renaming the VOB set(s) to VTS_01_* (obviously if I have multiple VTS's I need to copy them to seperate directories) and recreating the IFOs using http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit . I then import each VIDEO_TS folder and they import fine after that.If in doubt, Google it.
ConvertXToDVD - Help
By Simmons in forum Video ConversionReplies: 1Last Post: 10th May 2011, 00:07 -
Chapters in ConvertXtoDVD. Have a question.
By KTV86 in forum Authoring (DVD)Replies: 8Last Post: 15th Oct 2009, 04:35 -
ConvertXToDVD
By gjordan12198 in forum Newbie / General discussionsReplies: 8Last Post: 7th Jun 2008, 07:09 -
Convertxtodvd
By crowheart in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2008, 12:43 -
convertxtodvd
By matneaves in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 15:03
