Hi there, I have been browsing this forum and website for a while and i think i am suffering from information overload.
Basically what i want is the best method of converting .avi (divx) files from the .avi into .img or VIDEO_TS format, ready to burn with toast titanium 7 and then play on standalone DVD player.
I have ffmegx -- which i know how to use (just about) although i've struggled to find advice as to the optimum settings ( i know it varies depending on PAL etc etc ) - it works ok although i can't put chapter points in any films i encode or menus - any ideas? or do i need another prog for this.
I have also tried using toast titanium to do the encoding, which was pretty useless IMO - slow as all hell
I just tried using iDVD to encode, it seemed to work ok, although couldn't get chapter points in again, although thats probably just my inexperience
Just wondering - what would people recommend as the best method - given that i have QT / toast tit 7 / ffmegx / iDVD
I basically want to make DVD's wth a simple menu screen to select the episode i want . a background picture and maybe some music playing on the menu screen - and then a movie(s) encoded WITH chapter points
The sheer number of freeware/shareware/whateverware and guides here is confusing me a little so any straight shooting advice much appreciated..
thx
Here's what I do that works great for me, but it doesn't involve most of the programs you mention.
1. Pull out the audio to mp2 format using ffmpeggui
2. Convert the video to mpeg-2 format with dvd settings using TMPGEnc
3. multiplex the audio and video using TMPGEnc
4. Create the dvd structure and menus in TMPG DVD Author, which also converts it to the Video_TS folder
5. Burn the video_ts folder using Nero 6
Sometimes I have to cut the video using tmpg because when converting it will add an extra hour and a half of blank screen (no idea why). -
This is the MAC forum. Mac for macintosh, Mac for OS X. not PC and not Windows.
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 13:13 -
Help/Advice Converting .AVI Divx Files To ...
By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 16:18 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 01:09 -
Convert AVI to DVD best method advice required please
By vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 10:01 -
Advice on encoding TV Shows (VIDEO_TS to DivX)
By captvanhalen in forum ffmpegX general discussionReplies: 5Last Post: 10th Dec 2007, 10:48
