I have created a backup copy of a DVD using DVDFAB platinum onto hard disk (i.e VTS folder). Just before the menu kicks in there are various warning messages (copyright etc..), which seem to go on for ages!
Can I remove these using DVDFAB first?, or do I have to use another tool?
Any help, please.
Thanks.
I have never used DVDFAB platinum so i don't know about that but you can with VobBlanker.
No. Like Noahtuck recommended, VobBlanker will do the trick. I use it all the time to remove those pesky Studio Into & FBI warning clips. I even use to remove the protected by MV bragging clip. That gives me untold pleasure.
Download and install it. I don't know of any guides, but you can check it out under the tools section. Basicly, just select a titleset and in the pane below preview the various cells. Find the ones that contain the parts you want to blank out and blank them out. Save the results in another location (make sure you save them to a VIDEO_TS folder).
Originally Posted by carpy666
Just under the changelog there's a section called "guides for this tools". 6 guides there.If in doubt, Google it.
Add a jpg in a mkv file at the begining
By flash_49 in forum EditingReplies: 5Last Post: 20th May 2010, 18:17 -
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 05:35 -
Adding an advert to the begining of a flim
By john59 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Dec 2009, 19:10 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 12:07
