ok, i have always used NTSC video for my DVD player....but i was wondering..is there a way you can get PAL to play....what exactly is the difference? and can the difference be overcome?
What I have been doing, as most people suggest in this forum, is to rip a PAL DVD or VCD, re-encode it to NTSC with TMPGenc, and burn it to a new VCD, which will work with your NTSC DVD player and TV.
Most DVD players seem to be able to handle PAL or NTSC signals. The problem is usually whether or not your TV can. Usually, your TV will scroll a black and white image if it can't handle the PAL signal when a PAL VCD is played.
I'm curious to know if anyone has tried the Emerson EVC-1575 or 1595 video signal converters. Supposedly, they can automatically convert the DVD/VCD/VCR signals to what's compatible with your TV... I want to buy one, but I haven't gotten any reviews on their performance yet... anybody know?
Thanks...
--Porfirio -
if the dvd player does it right it will just convert the pal to ntsc and send that to the tv ( either squishing it into 240 lines of cutting off 24 lines off the top and bottom - mine, as do most dvd players, squishes the image)
getting the extra lines at the wrong frequency will confuse even the best tvs
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
