Hello everyone
I have a simple question
I have a pal DVD & when i watch it on pc it's superb....
tho on tv it ain't the same thing at all....
it is stretched...
& the persons on the movie seem stretched a bit...
I want to make it a ntsc to be able to watch it just like on my pc but on the DVD player
let me know if it's possible & how.
thanks!!!!!!!!!![]()
There are hundreds of posts on how to convert from PAL to NTSC. Search will find them. The most popular method involves a program called DGPulldown, however I don't know of a method that preserves the entire disc. Most just convert the movie and you have to re-author yourself. Search and you will find plenty of options.
NTSC vs PAL is not the cause of your AR problem though, and may not fix it.Read my blog here.
You can buy a DVD player that will play a PAL DVD but output it as NTSC.
In the "old days" many players that did this did it incorrectly so that you got an image that was "stretched" making everyone seem too tall and thin. At least that is what would happen if the PAL DVD was anamorphic widescreen. The same DVD palyers would slightly "squash" the image (make everyone look slightly too short and fat) if the PAL DVD was not anamorphic widescreen.
It sounds like you have such a DVD player.
So you have 3 choices ...
1.) Buy a new DVD player that does proper PAL to NTSC conversion.
2.) Use the TV OUT function of your computer's video card assuming your video card has that feature and it is a NTSC output. I believe that video cards with a TV out are either NTSC or PAL depending on what version of the video card you have (i.e., if bought in the USA it should be NTSC out if bought in the UK it should be PAL out).
3.) Re-encode the PAL DVD to NTSC format however this can be tricky to do just right but there are some guides on doing this.
Before going into any more detail on either of these 3 points I have to ask ... which way do you think you want to go?
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
How to watch PAL VHS on NTSC tv
By wolfhunter in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 15:36 -
DVP642 died. Do I want 3980 or 5990 for correct PAL to NTSC conversion?
By WinME in forum DVD & Blu-ray PlayersReplies: 19Last Post: 28th Apr 2009, 21:44 -
using NTSC TV as external monitor to watch PAL dvds played on laptop
By billybadbreaks in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2009, 15:27 -
Can I watch a PAL dvd on my computer?
By dredle1 in forum ComputerReplies: 7Last Post: 10th Oct 2008, 00:18
