I am looking for a stand alone tool (ie, no install) that will return information about a DVD such as copy protection type, region code, video length, and bitrates.
I know that various tools such as AnyDVD and DVD Decrypter can get this information, but I am looking for a tool that does not require installation. I searched through most of the tools on this site, but I could not find such a tool. If you know of one, can you please post its name and if possible, where I can get it?
Results 1 to 12 of 12
Thank you for the reply.
I haven't used DVDInfo, but from the website, description, and screenshot, it looks like this tool only displays information on DVD media and DVD drives. I am looking for information about the content of the DVD. I'm not able to verify this because the only downloads on the site appear to be installation files. I did download a zip file from the official site, but inside of it was an install file.
Do you or anyone else have another suggestion? -
whats up w/ the no installation part? is this not your computer? at work possibly?
Click the install file and install the software maybe.Originally Posted by Duallies
I don't have admin access to install anything.Originally Posted by Treebeard
As I said in my original post, I'm looking for a tool with no install.Originally Posted by ROF
You probably shouldn't be inserting unauthorized media into the system then.Originally Posted by Duallies
I am not restricted from playing DVDs on the computer, so they are not "unauthorized media".Originally Posted by ROF
Does anyone have a tool suggestion? -
do an install on another system and copy the exe file over
just a guess anyway ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
what about using media player classic ? no install there
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 04:51 -
Is there a tool to reveal a DVD's info, such as Bit stream mode...
By takearushfan in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2010, 23:13 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
What is the name of this video/audio info tool?
By ZoNi011 in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2010, 03:53 -
Tool for DVD-RAM version/revision info
By VirtualDoobMon in forum ComputerReplies: 2Last Post: 8th Aug 2008, 22:25
