Results 1 to 22 of 22
    Mar 2006
    someone recommended this forum, but the registration page does not work, and they do not answer e mails. Wondering if someone has some insights over there. Maybe other good lite on forum to recommend? thanks.
  2. Banned
    Feb 2005
    USA
    You could always try asking your question(s) here.
    Mar 2006
    Ok question:
    just need 2 links. one for a lite on recorder and one for hack.
    prefer a place with good return policy in case need return unit. also I'm on Mac. thanks. also anyone have phone number for tech Lite on?
  4. Mod Neophyte redwudz's Avatar
    USA
    Strange. I just registered at CD Freaks and it took less than 5 minutes to get my confirmation email and log on.
  5. Banned
    Feb 2005
    USA
    Lite-On does not offer tech support over the phone. You can post your tech question to them here.
    In order to provide links you must provide the model of lite-on your have.
    Feb 2005
    http://www.techolio.com/forums/phpBB2/viewforum.php?f=7
    thats a good forum for liteon
    the only nationwide store I know of that sells liteons are compusa.com
  7. Member Prot's Avatar
    Dec 2003
    Oregon
    Best Buy sells Lite-On as well.
    TANSTAAFL
  8. Banned
    Feb 2005
    USA
    Don't forget Walmart.
  9. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Also Officemax
    Mar 2006
    thanks Guys, good tips. Radio shack nearby sells the
    LVW5006
    LVW5105.
    They have high restocking fee, so I want to get his right, which one to get, and where to dowload the best hack so I can copy what I want -- and I'm on a Mac if that matters. thanks!
    Sep 2005
    Edmonton
    Id go with neither.
    Mar 2006
    thanks Meek,
    maybe you can't expand on that. why are they no good, and what is good to get?
    Mar 2006
    Red:
    please help out. just tried 2 more times with no luck:
    the field above the password? put something in there? Refer field need be filled in? I'm lost
  14. Mod Neophyte redwudz's Avatar
    USA
    CD Freaks: I'm not sure why there would be a problem there. They are just asking for a username. Add a couple of numbers to it if you have a common username. Or just make something up. I volunteered the minimal information and they registered me with no problems.
    If you are using a proxy server address to log on, that could be a problem?
    Mar 2006
    thanks Red.
    I think thats the problem, not entering anything in the field at the top with no name.
  16. Go to the site [solidsnake] gave. Go through it
    Than go here
    http://ncc2315.com/ilo/
    The ilo04 units, while WalMart, are a LiteOn [Now discontinued]
    Make sure that the LiteOn unit you select can be hacked They are disapearing fast
    Mar 2006
    Was going to get the 5006, do those links work for it LCS?
  18. [ Keys ]
    Yes
    Many of the latest LiteOn units cannot be hacked I believe the 5006 is one that can, The latest firmware cannot be hacked, but if on the unit, a previous version can be installed and than hacked.
    I do not have the LiteON but have two ilo units with HDD and one without HDD [they are made by LiteOn] and work very well
    Go to the first site I gave and look through it. There are posts that mention the 5006 and hack.
    If all else fails post the question to [Harpmaker] he is well versed on the LiteOn units.
    Look at the [Guitarman] posts and his comments at both sites given.
    Good Luck
    PS
    I Would prefer the LiteOn 5045 With HDD
    If need be grab the 5006 as the 5945 and 5006 are fast becoming no more.
    Mar 2006
    Just got the 5006, at store.
    Does it even need a hacK? I only have one pre-recorded disk, but with Sony it said, can't record, but records fine without any hack in the 5006.
    I do have an RF modulator, but that was more for VHS, don't thing it effects DVD recorders.
    Maybe lucky with this one commercial disc, but maybe 5006 records anything without hack?
    Also: with 5006, is there a title limit, or can you record unlimited titles, does anyone know?
    I have to say 5006 blows away the Samsung & Sony I had before.
    The Samsung would not play back any -R on my JVC player, and the Sony would not play back -RWs. But lite on plays back both perfectly. so why the issues with others?? and why is lite on so good?
  20. [ kevs ]
    Your quote
    "and why is lite on so good?"
    I notice that you went to one site I gave and posted there. The reply, and the other sites given answer your question
    Mar 2006
    Can't find LIte on at walmart of office max websites.
  22. Member
    Mar 2006
    thanks LSC appreciated that, but please offer you opinion on my questions -- I appreciate your viewpoint!
    also, I see a lite on 5005xk for sale, but is it same as 5006?
    Now that I had such great luck with 5006, reluctant to start experimenting. but was I just lucky?
