I have a movie and it's way to big to fit on one CD. How do I seperate it to fit onto 2 cd's?
Results 1 to 9 of 9
I suggest demuxing w/ TMPGenc and then re-muxing/cutting w/ bbMPEG. See the "Edit" section to the left for details.
What format is your movie in? I would suggest using Virtual Dub and make a selection of the movie you want to separate. Just make sure that the direct stream copy is selected on both video and audio, and it should only take a couple of minutes. There should be tutorial somewhere on vcdhelp.com too.
i suggest using a program called vcd cutter tis a dead simple program and u can download it from morpheus or kazaa wiv the crack.Using the program is like learning abc its that simple!
Whitto -
The best way is using M2 Edit Pro... Look for it at morpheus...
it works on mpeg1 and mpeg2 files.
I always use TMPGEnc - MPEG Tools, works great for me, although I do know of a problem with 2gb files or more.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Yea Sefy,
Yea I have tryed that but the quality gets a lot worse when I do that. Is this normal?
Quality should not be affected at all, it's only Demuxing and Remuxing, I can't see how your quality can be affected if there is no re-encoding being done, doesn't sound logical.
Best Regards,
Sefy Levy,
Sin City - movie over 50 seperate m2ts files - not all in sequence.
By Z.Sath in forum Blu-ray RippingReplies: 5Last Post: 11th Jun 2009, 16:45 -
Splitting a Movie into two parts
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 23:25 -
2 movies with seperate pagew for chapters of each movie possible?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 28th Aug 2007, 08:10 -
burning 2 parts of movie to 1 DVD
By popgun2k in forum DVD RippingReplies: 2Last Post: 27th Jun 2007, 10:07 -
how to rid discolored parts of movie
By tranzadikt in forum RestorationReplies: 3Last Post: 14th Jun 2007, 09:06
