Was going to archive the movie Elf, with the infinifilm content. Is there a way to grab the entire disk with the infinifilm content - meaning the DVD-Rom stuff also? Thanks.
A small effort of Manners goes a long way down the road
Any Ideas?
A small effort of Manners goes a long way down the road -
The simplest way - DVD Decrypter. ISO->Read, ISO->Write to a DL disc. Everything intact.
Otherwise
Rip the disc with DVD Fab Decrypter. This will probably skip the dvd-rom content, but that doesn't matter.
Manually copy the DVD-rom content to a folder on your HDD. Make sure you also copy any autorun.inf or associated files.
Reduce the size of the DVD Video content using your favourite tool. Make sure you allow extra space for the DVD-rom content. Write the results to your HDD. You should have a folder with two sub-folders - Video_TS and Audio_TS. Copy the DVD-Rom folder to this folder, giving you three sub-folders. Add the autorun files to the base of this, and burn the entire contents to a DVD disc. You might want to use imagetools classic to bundle the whole lot into an ISO, then burn with imgburn.Read my blog here.
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 08:52 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Upscaling SD content on PC...?
By snadge in forum Video ConversionReplies: 21Last Post: 29th Jul 2009, 23:22 -
Number 23 infinifilm overlays keep popping up on backup copy
By vulkrypse in forum DVD RippingReplies: 1Last Post: 17th Nov 2007, 01:49 -
Content
By stompinne in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2007, 13:18
