My dvd player supports mpg files. But, if I burn those mpg files on a dvd like any files then I have to skip file by file to reach the desired file. I want to burn the mpg files with a menu. But, if I use the menu feature of any burning software, it checks compatibility and tried to convert the mpg into a vob file, which is not what I want.
It is easy to build a menu with those mpg files when burning on a cd but I want it to do on a dvd disk. Is there any - any software which supports this feature. I tried quite a few but all tries to look for compatability.
thanks!
if you want a menu that works on most dvd players you must make a dvd-video with vob files.
how do you make a menu with mpg files on a cd? -
They have to be compliant files to make a DVD with menus. If they already are compliant most authoring software will not reencode(providing it has that ability) the video if you use the same attributes in the authoring software that your source video is. Some also have a option to specifically leave compliant video as is.Originally Posted by greendesert
DVD specs can be found here: https://www.videohelp.com/dvd
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 16:47 -
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 07:25 -
DVD burn for TV: hard disk camcorder mpeg-2 files edited in Vegas
By h08 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 23:39 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 15:10 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
