i have bought some DVD-R DL and i can't seem to be able to burn on them any movie, everytime i try dvd decryptor or imgburn give me an error about layer positionning. i use a NEC 3550a with firmware 1.05... i see must of you guys use DVD+R DL
i have tried this procedure with no luck
Instructions Rip w/ DVDDecrypter and AnyDVD- Burn w/ Imgburn:
1.In DVDDecrypter go to Tools> setings>General> untick Check for Structure protection
2.Now go to I/O and tick ELBYCDIO-Elaborate Bytes
3.Enable AnyDVD
4.Now insert Movie( foxes head turns red) and go to Mode in DVDD>Iso read> click the decrypt button. It will create 2 files- image and a .mds file
5.After ripping turn AnyDVD off ( right click taskbar foxes head and click on exit)
6.Open ImgBurn> Tools> Drive> Change Book Type>DVD-ROM
7. Now go to Mode> write> find the .mds file you created and click on it and the hit the write button
i'm quite sure if i really did changed the booktype since in the list i only see DVD+R DL and no DVD-R DL -
It depends on the drive you have, in your case stick with +R for all disks. It goes back to when the DVD Forum was at war with the DVD Alliance over which standard should prevail and they tended to build their drives to favor their own standards. I could be blowing smoke out my patoot though. I have found with my NEC 3540 it prefers Verbatim MCC003 +R (8X) and MCC004 +R (16X) and it more than likely applies to their +R-DL disks as well.
ok i will go buy some +R tonight.....
but when try to change book type it leave it to dvd-r dl how i do it is i go to
tools --> drive --> change booktype --> select nec ---> choose dvd+r dl (no dvd-r dl in the list) in the new setting i pick dvd-rom
it says it has been changed but it's still show dvd-r dl -
You can dig around here for some more info on your drive:
http://club.cdfreaks.com/forumdisplay.php?s=a44e07958b0c5715d3ae820b09ce7a9f&f=86
Liggy and Dee make some custom firmware for NEC drives:
http://liggydee.cdfreaks.com/page/
Buy good quality media and your experiences will be better:
http://www.digitalfaq.com/media/dvdmedia.htm
Try Taiyo Yudens or Verbatims
difference between burning DVD-4,7 GB and DVD-8GB
By michcio in forum DVD RippingReplies: 3Last Post: 2nd Jul 2009, 10:56 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 14:21 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
The difference between mpeg-2 and mpeg2-dvd in Premiere and the use in DVD
By umforrest in forum Video ConversionReplies: 5Last Post: 16th Jan 2008, 20:36 -
Can anyone actually TELL the difference between Blu-ray/HD-DVD over DVD?
By corvette77 in forum DVD & Blu-ray PlayersReplies: 62Last Post: 1st Dec 2007, 14:37
