everytime after l connected to the internet in windows 2000, there are some small windows keeps showing up telling me that my pc is affected and l need to download some software to stop it, are these spywares? l already installed service pack 4, but it still does not stop these annoying things from showing up, how to solve this problem? anyone?
That actually sounds exactly like what my brother got on his PC. Is it stopping from surfing at all, or are they just like pop-up advertisements ?
Google "Spyware Removal".
Ewido
Spybot
Ad-Aware
are all good IMHO. Also look for a pop-up blocker and possibly even a personal firewall such as Kerio and/or ZoneAlarm.If in doubt, Google it. -
Probably some spyware, yes. Try AdAware or similar.
/Mats -
Consider free download of and install Mozilla. I've been using Mozilla for about 4 years and have never had the first popup, and I'm also running Win2k SP4. Mozilla not only has totally effective popup blocking but spam blocking for email all built into the borwser with no need for third party popup blockers that may be less effective. Note some applications require Internet Explorer, but those sites are the only use I have for Internet Explorer and use Mozilla for everything else.
If all else fail, you can boot from floppy or plug the hard disk to another PC. Delete the Downloaded Program Files folder.
C:\WINDOWS\Downloaded Program Files
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
