newbie here, please help me.. i have a couple of mpeg-2 files that i need to convert to dvd. the mpeg-2 files are TV recordings with Japanese on the Left channel and English interpretation on the right channel. how do I split both languages into selectable audio streams in the dvd? ive just started using dvdlab ..
You can't. You need to demux the audio, open it in something that can read mp2 audio (or convert it to wav), copy the channel you want to keep over the one you don't, then re-encode the audio. Use this in DVD Lab Pro. If you want to have selectable audio, repeat the exercise, keeping the other channel, and use this as the second audio track.
Read my blog here.
Split channels of a dual-channel MP3 without re-encoding
By zuja9 in forum AudioReplies: 11Last Post: 19th Aug 2012, 19:15 -
.MKV Audio can only be split into 2 channels once extracted (I want 6)
By 54321blastoff in forum AudioReplies: 3Last Post: 28th Feb 2012, 19:31 -
Help - Split 6 Channels into separate WAVs
By stovk in forum AudioReplies: 6Last Post: 17th Dec 2011, 08:37 -
AC3 channels are split incorrectly
By silvertoaster in forum AudioReplies: 2Last Post: 23rd May 2011, 23:10 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28
